FOSI error message
    Yes and like you I couldn't find the problem and again like you it had no impact. But your right it bugs the bejezzes out of me when I get it. Sorry wish I could be more help.
    It seem like these messages must be coming from some FOSI somewhere. I suggest searching for specval in any .fos files in the relevant file system and the Arbortext distributed files.
    Good luck!
    Suzanne Napoleon
    www.FOSIexpert.com
    "WYSIWYG is last-century technology!
    LynnHales1-VisitorAuthor
    Suzanne,
    I’ll do that, but that still won’t cure the problem of it showing up. If I do find one or more <specval>s like that, especially in the Arbortext distributed files I’ll pass that information along so PTC can find and FIX the problem.
    Thanks.
    Lynn
    Suzanne,
    I went through the FOSIs I have on my system and those in the distributed Epic files.
    There is one <specval> in the distributed Epic files and nearly 900 in the various iterations of FOSI’s on my system. I searched for ‘attval=”2” | attval=”3”’. The results is there are no <specval>s with a value of 2, they are all 3. So the error of an <att> with a <specval> of 2 is really weird.
    Lynn
    What version are you using?
    Suzanne
