Oct 7, 2010 10:11 PM UTC
FOSI formatting a title to span a 2 col page
I have a page in which the title of the section/chapter spans the two
columns of text that make oup the text. At least that is what I want. The
page composes with 2 columns of text and the heading wrapped in the first
column. I wen in and checked the CALS sample and saw that they placed a
span of 2 on their title elements, so I tried that. That causes the title
to span the 2 columns but now the page content is just set as a single
column. I checked the CALS sample para0 tag to see if it reset the column
value it did; to 0.
I did the same thing to the first element after my title. No change. Title
spans the two columns and the body text is in a single column.
What did I miss?
..dan
    Oct 8, 2010 1:16 PM UTC
    Maybe I missed something, but...
    Put the title in the header of the page? And if you only want it on one page, either don't have a header on the other pages (e.g., header on recto1), or use a variable/pseudo-element to fill the header and reset that to '' before the following page(s).
    Untested on this occasion, but something we've done.
    YMMV,
    Steve Thompson
    +1(316)977-0515
    Oct 8, 2010 2:39 PM UTC
    Yeah that is one option - actually what I'm changing from. For one thing,
    in the Editor you don't get a title to display, werhe all the single
    column sections will have the titles. I mainly moved it because I get
    tired of trying to find where the formatting is being applied. I seem to
    get inconsistent results when I try to style things in the page
    definitions rather than hard coding what I want on the page.
    Anyway as a followup. There seems to be some relationsip between my title
    and needing a para element to immediatly follow - and it has to have
    conent. I discovered this by accident when I put in some debugging text
    and happened to put in a para - viola! I now have my title spannign the
    page, this para in the first colum (shich I need to get rid of) and the
    narrow table of information that I do want to display.
    I discovered this at the end of the day so I haven't poked around a whole
    lot, but it seems like all the settings are the same that I would expect
    to have some affect on the column layout and I'm not finding anything
    different.
    ..dan
    > YMMV,
    > Steve Thompson
    > +1(316)977-0515
    Oct 8, 2010 2:52 PM UTC
    Look up span in the help. I don't have time for more right now.
    -Andy
    \ / Andy Esslinger LM Aero Tech Order Data
    _____-/\-_____ (817) 279-0442 1 Lockheed Blvd MZ 4285
    \_\/_/ (817) 777-3047 Fort Worth, TX 76108
    Oct 8, 2010 2:56 PM UTC
    That is the value I tweaked originally and it changes my page layout for
    the title, but it is also affecting the rest of the content that follows.
    ..dan
    Oct 8, 2010 4:11 PM UTC
    Hello Dan,
    if I understand so properly you do a span in the title
    and get the following:
    titletitletitletitletitletitletitletitletitle
    columncolumn1
    columncolumn2
    columncolumn3
    columncolumn4
    columncolumn5
    columncolumn6
    columncolumn7
    columncolumn8
    And you expect:
    columncolumn1 columncolumn5
    columncolumn2 columncolumn6
    columncolumn3 columncolumn7
    columncolumn4 columncolumn8
    One cause can be, that after "columncolumn8" a page break is forced.
    The property "Balance" (set in "flow text area" at the page model)
    decides if in this case one or both colums are used.
    Balance = "yes" forces the equal use of both columns
    Balance = "no" may be the value that is set.
    Regards
    Jürgen Schnurr
    Technische Dokumentation
    Oct 8, 2010 4:26 PM UTC
    > Hello Dan,
    > columncolumn1
    > columncolumn2
    > columncolumn3
    > columncolumn4
    > columncolumn5
    > columncolumn6
    > columncolumn7
    > columncolumn8
    That was one scenario I got, here is the other
    titletitletitle
    titletitle
    columncolumn1
    columncolumn2
    columncolumn3
    columncolumn4
    columncolumn5
    columncolumn6
    columncolumn7
    columncolumn8
    > And you expect:
    Yes. I have succeed in getting this:
    titletitletitle
    titletitle
    but only after I introduce a para element. My content is a simple table
    that I have my own element names for, that I then FOSI generate a CALS
    table. So all my conent is a long CALS table.
    Hadn't thought about this, but the balance was set to 1/yes.
    ..dan
    > Regards
    > Jürgen Schnurr
    Oct 8, 2010 4:47 PM UTC
    So I got it to work but logically I don't understand.
    I would have thought that span like in a table would be indicating how
    many columns to span. So I was setting my title span to 2. I would think
    that this also would only affect the title element and not content the
    followed, but that doesn't seem to be true either.
    So the correct setting for span on the title is 1, that got a title
    spanning the page, but it also caused my table to be in a single column as
    well. When I set the span on the table to 2, I then got the table the way
    I wanted and deleting the extra para still kept the table in 2 cols.
    What I don't understand is the para element didn't have anything set and
    it would cause the content to split into 2 columns. Is it just something
    about tables again?
    ..dan
    Oct 8, 2010 5:02 PM UTC
    <e-i-c gi="title" context="table">
    <charlist envname="titleenv">
    <quadding inherit="0" quad="center" lastquad="relative">
    <postsp nominal="6pt" condit="discard" priority="high">
    <keeps keep="1" widowct="3" next="1">
    <textbrk startln="1" endln="1">
    <suppress sup="1">
    </charlist>
    </e-i-c>
    [cid:image001.png@01CB66E0.66A70380]
