Mar 13, 2020 7:15 PM UTC
FOSI savetext in fillval with ACL
Using the FOSI in ArborText v6.1 I am trying to convert XML content to upper case for PDF bookmark. I using the following in the FOSI.
<att>
<fillval attname="pdfbookmark::changeCase" attloc="SYSTEM-FUNC" fillcat="savetext" fillchar="conrule">
<charsubset><savetext textid="subject.pdf" append="1"></charsubset>
</att>
With the ACL
package pdfbookmark;
function changeCase(window,oid){
return toupper(oid_content(oid))
When I publish the using the FOSI the savetext content is not shown.
When I use the same ACL for usetext in fillval it works.
Not sure why this is not working.
Mar 16, 2020 5:42 PM UTC
You could try saving the return value to an unappended string and then saving that to the appended string. If that doesn't work, a solution using an ACL preprint process follows.
<charsubset>
<savetext textid="subject.tmp" append="0">
<savetext textid="subject.pdf" conrule="subject.tmp" append="1">
</charsubset>
If the above doesn't work, this should:
1. Add a pseudo-attribute to be used by the title element.
2. Develop an ACL preprint process that finds each title, converts it to all caps, and writes it to the pseudo-attribute.
3. Change the FOSI to fillval from the pseudo-attribute instead of using #CONTENT.
Good luck!
Suzanne
Mar 14, 2020 6:41 PM UTC
I don't think you need ACL for this. The highlt category can be used for all caps. For example:
<highlt inherit="1" allcap="1">
You can code highlt in a formatting pseudo-element and save it with #CONTENT to a text string:
<e-i-c gi="allcaps.fmt">
<charlist inherit="1">
</charlist>
</e-i-c>
<savetext conrule="<allcaps.fmt>,#CONtENT,</allcaps.fmt>" textid=...
The highlt category is documented in Arbortext Help and in my book Practical FOSI, which is available at fosiexpert.com/Practical-FOSI.html. My FOSI QuickStart Tutorials are also available on my website.
Good luck!
Suzanne Napoleon
www.FOSIexpert.com
"WYSIWYG is last-century technology!"
bschanck5-Regular MemberAuthor
Mar 14, 2020 7:13 PM UTC
I had tried that originally, but since this is used to create the PDF bookmark, this is ignored. That is why I was trying to use the ACL to force the text to be upper case.
Again, the ACL worked when used with usetext, but not savetext.
Mar 15, 2020 11:58 PM UTC
I'm not sure I'm following you. Are you saying you tried this:
<savetext conrule="<allcaps.fmt>,#CONTENT,</allcaps.fmt>" textid="subject.pdf" append="1">
and it didn't work?
