Aug 7, 2014 7:09 PM UTC
Graphic Respository
We currently are storing our graphic files on a seperate network as a repository. We have had issues with the network, where it might be down but our Composer is still composing. The result is not graphics in the PDF. We also have to change our network mapping daily, because the server has be replaced and points elsewhere. Is there a place in Arbortext Editior for such a repository?
TimPhelpsAnswer
Aug 7, 2014 8:29 PM UTC
Sorry, but in the previous note I stated
C:\Program Files\PTC\Arbortext PE\custom\doctypes
but I meant to type
C:\Program Files\PTC\Arbortext PE\custom\graphics
If you are going to place the graphics on the PE server, then
1) Place the graphics in the C:\Program Files\PTC\Arbortext PE\custom\graphics directory
2) Restart Tomcat so the PE Publishing Engine sees the graphics
3) On the Arbortext Editor clients set the environment variable APTGRPATH to point to C:\Program Files\PTC\Arbortext PE\custom\graphics
TIm
Aug 7, 2014 7:16 PM UTC
Have you thought about using the custom\graphics directory in the install path for Arbortext Publishing Engine on the PE server? Arbortext Editor clients could point to the PE server rather than your other network location.
Best regards,
Tim
clake1-VisitorAuthor
Aug 7, 2014 8:00 PM UTC
Where is this custom\graphics directory?
Aug 7, 2014 8:05 PM UTC
On the PE server, in the Arbortext Publishing Engine Install Path. Generally, the path is C:\Program Files\PTC\Arbortext PE\custom\doctypes
Tim
