Graphics disappear when published to Web
I've created a book in Editor and when I publish to PDF the graphics are there, when I publish to Web the grpahics do not appear in html. Any ideas on what the problem could be?
The graphics are jpegs that have been altered in Illustrator to include text and shapes on top of the photo. Then exported as jpeg again.
Hi April,
I recommend you file a technical support case for this issue. Be sure to include a document that references one of your modified jpeg graphics. You should capture the document and graphic along with the stylesheet in an appsave. Click the link below to learn more about creating an appsave.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS146968
Jerry Tippie
