Graphics in sub-directory
Again troubled with images...
I'va tried to set the graphics path in the preferences of the editor (Arbortext 6 M010) as a sub-directory but whatever the way I write it it doesn't work:
I have all graphics in a sub-sub-folder named "cuadernoestudio/images_xml" and in the graphics path I've tried with the proper use of colons and all variations of " and "/"):
"cuadernoestudio\images_xml"
______________________________
    18-Opal
    May 20, 2013
    Hi Gabriel--
    Did you try prefixing the path with a dot "." (for current directory)?
    Try this:
    "./cuadernoestudio/images_xml"
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    1380 Forest Park Circle, Suite 100
    Lafayette, CO 80027
    Hi Clay,
    No, It doesn't work.
    Before having to reinstall the Editor, I would like to know if I I'm missing something, or It's simply a malfunction of my Editor...
    Gabriel Oreggioni
    If there is a finite number of paths preceding your "cuadernoestudio\images_xml" directory, you can list all of the potential paths separated by semi-colons.
    i.e.
    pathA\cuadernoestudio\images_xml; pathB\cuadernoestudio\images_xml; pathC\cuadernoestudio\images_xml; etc. etc. I don't know what the limit is on the number of paths you can use, or if there is a limit at all.
    If the possibilities are infinite, then I have no more suggestions, other than to tell you to place all of your images in the same folder(s) on the network and use unique filenames.
