Handling multiple PCF profiling files
I have a feeling that I'm missing something regarding handling PCF files for profiling.
We have many document sets that are created in DocBook and DITA, where each document set has
different profiling requirements.
As far as I can see, the PCF file that defines the valid profiling values has to be
in /custom/doctypes/axdocbook or /custom/doctypes/ditabase (or in some other fixed location defined
in the DCF file).
Currently we swap out the PCF file under /custom/doctypes/ according to the document set that we are
working with.
This is cumbersome. Have I missed something basic here? Just for example, I would have expected
that a PCF in the same folder as the XML file would be used in preference to the PCF file
under /custom/doctypes but that does not appear to be the case.
Any suggestions?
Martin
Kongsberg Maritime
www.km.kongsberg.com
    18-Opal
    September 30, 2012
    Hi Martin--
    You can switch PCF files, out, but the way you do it is a bit indirect.
    To make this work, you need to define a function that loads the PCF file
    you want to use and returns the ACL doc ID for that PCF document, then
    attach that function as a profiledochook, something like this:
    function load_profile(doc = current_doc()) {
    # doc_open flags: readonly, no warnings/errors, no stylesheet, don't
    prompt for doctype
    local FLAGS = 0x001 | 0x020 | 0x200 | 0x400;
    # check for PCF file in doc directory
    local docdir = doc_dir(doc);
    local pcfs[];
    glob(docdir . $main::PCS . "*.pcf", pcfs);
    if (count(pcfs)>0) {
    # found one, so let's use it
    local pcfdoc = doc_open(pcfs[1], FLAGS);
    return pcfdoc;
    else {
    # no special file found, so just load default doctype PCF
    return 0;
    # add hook function
    add_hook("profiledochook","prof_config::profile_doc_loader");
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    mbushby1-VisitorAuthor
    And that method works like a charm.
    Thanks a lot Clay!
    Martin
    18-Opal
    October 1, 2012
    You're welcome, glad it worked for you.
    --Clay
    Sent from my iPad
