Oct 21, 2016 7:53 AM UTC
Hello, I use the app layout when it is now the xml file into a 3d file layout, but the changes in the 3d file is not synchronized to the xml,does the app has this feature can be 3d file layout changes in the synchronization to xml document?
Oct 22, 2016 7:00 AM UTC
Yes, you can have content be linked into the .3D file. When you save the .3D it can then update the linked content with any changes you've made.
hyifan1-VisitorAuthor
Oct 24, 2016 1:32 AM UTC
Thank you very much, if not may you trouble, can you say how to connect xml file and .3D file?
Oct 24, 2016 5:47 AM UTC
The relevant macros you should use are "tft*" "tlink" and "ttlchk".
