help with XPATH
how can I have a tag check its content? I can't use starts-with because I want the answer to be "1" and there is also a "10".
I am looking for when hazid = 1 or the first time hazid has content.
(And how would another tag check hazid's content?)
Thanks!
    If you're "on" hazid, you could do: self::hazid[. = '1']
    or just: self::*[. = '1']
    If you're on, say, the parent of hazid: child::hazid[. = '1']
    or just: hazid[. = '1'] (since "child" is the default axis, or "direction
    of travel within the tree/graph/document")
    If you need to get to hazid from somewhere else, please describe it.
    By way of explanation, "." is short for "self::node()", a.k.a. "the current
    node". Comparing it with a string ('1') causes XPath to take the "string
    value" of the node, which is all of the text content (recursively), for an
    element.
    -Brandon 🙂
    On Mon, Apr 23, 2012 at 10:22 PM, Caroline Leccese <
    > Thanks!
    cleccese1-VisitorAuthor
    Thanks Brandon! I want to check from <icon>
    <exp>
    <icon><title></title><hazid></hazid><hazdesc></hazdesc>
    </exp>
    from icon: following-sibling::hazid[. = '1']
    is not right...it is coming up true when hazid is empty as well as when hazid = 1
    you could try combining with thenormalize-space() function
    Tracey
    On Thu, Apr 26, 2012 at 1:38 PM, Caroline Leccese
    > -----End Original Message-----
    From your example, it seemed like you should be using the "child" axis (or
    none at all, since "child" is the default), rather than
    "following-sibling", since you indicated that your context was an element
    that appeared to be the parent of "hazid".
    Can you give us more details of the case where you're not getting the
    results you expect? A document fragment including both the hazid you're
    looking at, as well as the context element. Also, how are these XPath
    expressions being evaluated? In Styler, using ACL functions in Editor, in
    something completely different...?
    -Brandon 🙂
    On Wed, Apr 25, 2012 at 11:38 PM, Caroline Leccese <
    > hazid = 1
    My mistake, <icon/> is a single tag, it is not the parent of hazid (as I understand it)
    Via styler 5.4, I am inserting a condition onto <icon/> using xpath: following-sibling::hazid[. = '1'] is true
    If I put test gentext "
    <exp>
    TRUE <icon><title>title</title> <hazid></hazid><hazdesc>text.</hazdesc>
    TRUE<icon><title>title</title><hazid>2</hazid><hazdesc>text</hazdesc>
    <icon><title>title</title><hazid>4</hazid><hazdesc>text</hazdesc>
    </exp>
    Thanks for any help!
    As Tracey mentioned, use
    At icon element, use the following xpath:
    following-sibling::hazid[normalise-space(.) = '1']
    On Thu, Apr 26, 2012 at 4:58 PM, Caroline Leccese <
    > understand it)
    > If I put test gentext "*TRUE*" before icon for the condition, this is
    > what happens:
    > <exp>
    > *TRUE*<icon><title>title</title>*<hazid></hazid>*<hazdesc>text.</hazdesc>
    > *TRUE*<icon><title>title</title>*<hazid>1</hazid>*<hazdesc>text</hazdesc>
    > <icon><title>title</title>*<hazid>2</hazid>*<hazdesc>text</hazdesc>
    > <icon><title>title</title>*<hazid>3</hazid>*<hazdesc>text</hazdesc>
    > <icon><title>title</title>*<hazid>4</hazid>*<hazdesc>text</hazdesc>
    > </exp>
    Let's break the XPath down to see why this is happening. The first part,
    "following-sibling::hazid", returns a node-set consisting of all of the
    "hazid" elements that follow the context node and are children of the same
    parent element. In your example, this is every hazid until the closing
    "exp" tag.
    The second part, "[. = '1']", filters the set of nodes to just those for
    which the string-value of the node (".") is equal to the string "1".
    Because we're evaluating this is a boolean (true/false) condition, XPath
    then converts the node-set to a boolean value, for which the rule is to
    return false if the node-set is empty and true otherwise.
    Since the first four "icon" elements are all followed by a "hazid" whose
    content is equal to "1", they all match the condition. It seems that your
    real requirement is to match those "icon" elements for which the *next*
    "hazid" is equal to "1". For this, we can include a "positional"
    predicate, as follows:
    following-sibling::hazid[1][. = '1']
    Here, the "[1]" filters the node-set to just the first item within it, then
    applies the content-based filter, as before.
    For the record, the "normalize-space" function can be very useful in
    dealing with arbitrary data which may contain arbitrary white space, and I
    wouldn't disagree with using it here, in addition to the above change, to
    make the condition more robust.
    -Brandon 🙂
    On Thu, Apr 26, 2012 at 12:58 AM, Caroline Leccese <
    > understand it)
    > what happens:
    > <exp>
    > </exp>
    Thanks, everyone!
    following-sibling::hazid[1][normalize-space(.) = '1'] worked as I wished.
    Is there a way to write the condition in Styler so it doesn't convert to a Boolean and just checks the value?
    Why don't you use the simple test :
    following-sibling::hazid[text()='1']
    does it also return true when hazid is empty ?
    Yves Deniard
    MBDA France
