Dec 5, 2011 3:07 PM UTC
Hide Attribute
In our schema we have a attribute called rowsep which is available in <table>, <row>, <colspec> and <entry>. I want to hide this attribute in all elements except <entry>.
I tried the dialoghidden option in the dcf file but that will hide the attribute in all element. Is there a workaround of this.
Karthik
    18-Opal
    Dec 5, 2011 4:18 PM UTC
    Hi Karthik--
    You might need to write some custom code and use it as a modify_tag
    document callback. The code would need to check the current element
    name, and if it's table, row, or colspec, withdraw the control for the
    rowsep attribute.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    Dec 5, 2011 4:47 PM UTC
    Okay. Thanks Clay.
