Hot key "Ctrl+Shift+="
Hello
I try to use this hot key to popup a line in front another without success (on azerty keyboard , isodraw 7)
Anyone know why this command doesn t work ?
Thanks in advance.
    I am a "longtimeIsoDrawuser" and I always use short cuts - but I've never heard about that one (strg+shift+=). Tell me more about - did it ever work in former versions?
    I only know this ones around that point:http://www.balko.macbay.de/Austausch/IsoDraw/shortcut.jpg (strg+shift++ or strg+shift+-)
    pierre11-VisitorAuthor
    i m too a "long time user" Before i used isodraw 6 and the shorcuts for popup and popback was like you use atm (ctrl + + to popup and ctrl + - to popback french version of isodraw).So i moved on version 7 and now the hotkeys are different : Ctrl+Maj(Shift)+ - to popback (this command work fine) for the other popup Ctrl+Maj(Shift)+= there s nothing happening , i have to "right click" and select "popup" it s annoying...
    I think maybe because i push on Shift the = become + .....
    Attached there s a picture of desktop....
    thanks for your answer sorry for my english
    Ah - now I know what you mean. I think it is a "translation" fault which is caused by PTC.
    http://www.balko.macbay.de/Austausch/IsoDraw/shortcut2.jpg
    Here you can see how it is descripted in the german version - so I think you should use the button "+" instead of "=" ...
