Aug 17, 2016 12:38 PM UTC
Hotlinks in a List of Effective Pages
I have a FOSI for a document type which generates an LEP.
The LEP is generated by outputting the relevant page info from the pagespecs I have defined and it works fine.
However, what I don't have is any hotlink between the LEP entries and the matching pages.
I tried setting  the 'hotlink' and 'status' attributes as I have for the TOC but to no effect.
I am beginning to think this is a limitation of generating the LEP content from the page spec rather than from the elements in the content as I have done for the TOC.
Does anybody know of a way to achieve hotlinks from the LEP entries?
Adrian Jordin
    Aug 17, 2016 1:29 PM UTC
    There are brute force options.  We use an inline element with a IDREFS att, and generate those into the LEP entries by putting the markup into the savetext.  You can also post-process with a little ACL to generate the links.  Pagespec folios (and footers) can be a little goofy, especially with textvars and scoping.
