how can i delete all the "P"sign at once?
I often copy some table from the "excel" of the office software to the Arbotext, but each content has the "p" sign (see the picture)
how can i delete all the "P" sign at once? not hide them
please help me thanks very much!!!!!!!!
    bfriesen
    bfriesenAnswer
    18-Opal
    August 8, 2013
    There is a icon in the tool bar that has a markup tag with a red X through it. If you click into the P element and click the button it will go away. If you select muliple cells it will only delete the markup in the last one selected. I made the same request to ptc support and was told the program is functioning correctly. I would expect that it should remove all the elements from the cells selected.
    Here is the work around that I recieved posting this same question in the forums.
    Create an acl script. Open a text editor copy the info below and paste it into the text editor save as remove_p.acl.
    function remove_p_tags()
    local oid = oid_first_tag()
    local cnt
    local i = 1
    cnt = oid_find_children(oid, $arr, "p")
    for ($i=1; $i<=$cnt; $i+=1)
    if (oid_name(oid_parent($arr[$i])) == "entry")
    goto_oid($arr[$i],-1)
    dt
    map F10 remove_p_tags();
    Save this file in the init folder, restart your editor session, Click into your table and press F10, it should invoke the script to remove all the P elements.
    Hope this helps
    Bryon
    Ps if you are using Excel, you can choose edit paste as excel, it then removes the P elements from the table.
    bfriesen
    bfriesen18-OpalAnswer
    18-Opal
    August 8, 2013
    local cnt
    local i = 1
    dt
    Hope this helps
    Bryon
    it's very useful ,thank you!!!
