Feb 28, 2025 3:12 PM UTC
How can I execute a custom function before publishing the document using a Styler stylesheet?
We would like to perform some custom action (copying files from remote server) before the publishing action is performed from the "Publish" dialog box. Ho can we embed/ perform our custom actins before the publishing action takes place.
Community Moderator
Mar 11, 2025 4:52 PM UTC
Hi @PV_12583628,
Thank you for your question.
Anurag
18-Opal
Mar 18, 2025 2:40 PM UTC
You can use the composition framework hook for this. Define a function in ACL that does what you need to have happen, and attach it as a hook function. This is described in the help center:
https://support.ptc.com/help/arbortext/r8.2.3.0/en/#page/PE%2Fpeprog%2Fpe3102.html
https://support.ptc.com/help/arbortext/r8.2.3.0/en/index.html#page/Program/acl_ref/help22635.html
