Oct 11, 2014 7:29 AM UTC
How can I restrict the image size in the table and the page?
Dear all,
I met a problem, when I using the styleshhet(.style file) which is customized for publish a document, the image is over the table and the page, but when I change to use the default stylesheet (for example: ditabase.style), it's ok.
But I didn't know how to set the restrictions, could you tell me or give any suggestion?
Your assistance will be highly appreciated in this regard.
Thanking you!
rdiazAnswer
Nov 7, 2014 4:33 PM UTC
Not certain I'm following your use case.
You control the graphic through the stylesheet? Are you inserting it as gentext, or just modifying it based on it's context? You stated in ditabase, it works fine. Can you compare what property sets and keeps settings are different between the two?
Oct 18, 2014 1:17 AM UTC
Is the image scaled smaller in the ditabase.style file?
Are there KEEPS set that prevent a page break between the figure and table?
This could cause the page to overflow.
Oct 31, 2014 12:11 PM UTC
Hi Lorin,
Was Tim's input useful? Are you still having issues? Let us know. Thanks!
lxie11-VisitorAuthor
Nov 1, 2014 2:26 AM UTC
Yes, I have set it useful, maybe it's correct.
But I didn't use this way, I control it by other method in stylesheet, and I find it's hard to me to find detail information here
