How can I use an ACL code inside the APP?
Hi all,
I need to use a acl code inside the APP code, and save the informations that the ACL retrieves in a variable.
Hi Robson,
ACL code is an Arbortext Editor language and won't execute inside of APP code. If you need to pass variable information between the 2 applications, I would use Javascript or Perl which are 2 languages that both applications support.
Out of curiosity, what information are you trying to pass from APP and to where?
-Jeff
rboneti1-VisitorAuthor
Hi Jeff,
Actually, I could do it with this:
formatting.evaluateXPath("_acl:eval(here the acl code)")
But would be better if was possible to do this without xpath.
Answaring your question, I want to save a value in a variable and use in another element, like a global variable. And for this, I've found two ways:
application.variables and the acl ENV['name']
That's a neat trick, but we have noticed with newer APP (Arbortext) releases that formatting.evaluateXPath() will now only work in a formatting context. That is to say, if try and run a script with that method it won't work. If you run that method from within a formatting tag then it will still work.
Either way, while I like your trick I'm not sure it is the best way to pass information between Arbortext/APP. It feels like that would be something liable to change or break between APP/Arbortext releases. It would be interesting to learn what you are trying to achieve in order to advise if there is a better way.
