bfriesen
18-Opal
May 10, 2016 8:45 PM UTC
How do I combine two macros in to one?
Hi all, I have two macros one creates a jpg the other a cgm. what do I need to do to make them work as one.
Macro export jpeg
# recorded with Arbortext IsoDraw 7.3
  Save
  Define final as string
    final="X:\Photos\" + stripext(activedoc.name) + ".jpg"
    Export final "JPEG"
End Macro
Macro export CGM to sp_windrower image folder
  app.interaction=false
  Save
    final="X:\Dita Documents\English\Products\sp_windrower\Images\" + stripext(activedoc.name) + ".cgm"
    Export final "cgm"
  app.interaction=true
End Macro
thanks
Bryon
bfriesen
bfriesenAnswer
18-Opal
May 13, 2016 5:35 PM UTC
Thanks Trevor, I will go back and modify all the names to remove spaces. This is what I figured out to work
  Save
  Define final2 as string
    final2="X:\Photos\" + stripext(activedoc.name) + ".jpg"
    Export final2 "JPEG"
  Save
    Export final "cgm"
End Macro
Bryon
May 13, 2016 3:34 PM UTC
First, I don't believe you can have spaces in your macro name. Either way, it's not good practice. I personally use an underscore (_) as a space replacement. Based on that...
Say you have your two macros, Macro CGM_Export and Macro JPG_Export. If you want to simply combine them you can call them from a third by doing the following.
Macro Export_All
     Run CGM_Export
     Run JPG_Export
End Macro
If you want to hide the submacros you can either change them to submacros or add 'Not_In_Menu' after the macro name in the macro itself.
bfriesen
bfriesen18-OpalAuthorAnswer
18-Opal
  Save
  Save
    Export final "cgm"
End Macro
Bryon
May 27, 2016 3:17 PM UTC
Hi Bryon,
Did the modification work out for you?
Let us know if there's any follow-up for the community.
Thanks!
