How does the macro syntax work? I'm trying to extract variables from element properties
As part of a macro, I'm trying to work out the approximate perimiter of a selected ellipse.
I'm falling down right at the start because I don't understand how to extract the information needed to do the working out.
In my macro, the user selects an ellipse. I then want to extract various bits of information from the ellipse
properties in order to work out the approximate perimiter.
Below is an extract of what I've done so far - it is not correct though, as it doesn't work!
macro cylinder_properties
define ellipse_pt as element
define start_angle as string
define me as MouseEvent
me = Wait MouseClick
ellipse_pt = me.ptMMGrid
Select at pt.x pt.y
start_angle = ellipse_pt.ellipse.segments[1].startAngle
#TO TEST IT I JUST WANTED TO DISPLAY ON SCREEN THE VALUE IT'S FOUND FOR start_angle BUT IT GIVES A SYNTAX ERROR
message 'ellipse segment start angle is: ' + start_angle
end macro
I've not figured out yet how you extract data using the language, so can anyone help me?
I find that the lack of any kind of guide to the syntax of the macro language makes things very difficult - why is it so poorly documented? I'm used to having a 'trace' function that allows you to follow what a macro does and pinpoints
where errors occur - is there anything like this in Isodraw?
Any help would be much appreciated.
    The problem with the macro is that the ellipse_pt element is not being set. To correct, insert "ellipse_pt = ActiveDoc.FirstSelectedElement" after your select statement.
    In regards to troubleshoot, though it's not the best, you can go through the menu to Macros | Macros | Debug macro...
    Within this utility you can run a macro line by line monitoring up to three variables while moving through (note that if you are using a local variable, you can't select until you've defined it).
    TimSharp1-VisitorAuthor
    Thanks for your help Trevor.
    Unfortunately I did have the ellipse_pt = ActiveDoc.FirstSelectedElement statement in my macro, I just missed copying it to my post in my effort to cut it down to just the relevant bits of code!
    I have noticed that I don't get the error if I select an ellipse before I run the macro. If I don't select it first, then I get the error, suggesting that the macro won't select the ellipse in the wait mousclick bit. Should I be selecting the ellipse in a different way? We have element points set to magnetic, but do macros not use this?
    macro cylinder_box
    define ellipse_pt as point
    define picked_ellipse as element
    define end_angle as string
    Select at pt.x pt.y
    picked_ellipse = activeDoc.firstSelectedElement
    start_angle = picked_ellipse.ellipse.segments[1].startAngle
    end_angle = picked_ellipse.ellipse.segments[1].endAngle
    #MESSAGE BELOW DOESN'T WORK - SYNTAX ERROR.
    message 'ellipse segment start angle is: ' + start_angle + '. end angle is:' + end_angle
    end macro
    I haven't 'twigged' the rules of this language yet, I wish there was a tutorial somewhere explaining the basics of how it works - perhaps that is a future seminar you could do?
    A couple different approaches.
    Easiest: Select the ellipse and then run the macro.
    2nd option: Put a loop in that checks if the select statement actually selects an ellipse. This will help with the situation you mention above, as well as when a user selects text or a normal line. If you go with this second approach I'd recommend atleast temporarily adjusting the snap distance (I believe the default is 5 pixels) so that selection of the ellipse is easier.
    If you choose the second let me know and I can help with the syntax.
