How to call a public static void main(String[] args) method in an ACL function
I begin to do a java class, but I have a problem to call the "main" method in Arbortext.
My java class:
public class HelloObjIs
public static void main (String args[])
System.out.println("Hello");
How to call a public static void main(String[] args) method in an ACL function ?
    Hi David,
    to call a static method from ACL you have to use the java_static() ACL function. In your case the call would be:
    ret = java_static("HelloObjIs","main",args);
    Now for the args you need to convert an ACL array to a Java array. Basically you would do the following in ACL:
    local myarr[];
    # ... put in values as needed or leave empty...
    myarr[1] = "something";
    # now convert to Java array
    local obj = java_array_from_acl(myarr,"[Ljava/lang/String;");
    # now call your static method with parameters
    ret = java_static("HelloObjIs","main",obj);
    Hope that helps.
    Kind regards
    Sirko
    Hi David,
    local myarr[];
    Hope that helps.
    Kind regards
    Sirko
    dgopois13-AquamarineAuthor
    Hi Sirko,
    Thank you for your help.
    Kind regards
    David
