3-Newcomer
How to correct a A11118 Stylesheet error
Turning context rules on would cause character entity to be out of context . Context rules are still off.
Turning it off does nothing
bfriesen
18-Opal
When you try and turn on context rules and there is an error present, the program should take you to the spot where the issue is. You will need to correct the issue before context rules can be turned back on.
Bryon
