Nov 19, 2014 11:41 AM UTC
How to deal with the box across pages?
Dear all,
I using the FOSI and the APP source edit for the box, but when the box across pages, we lost 2 line, can I add it in the source edit? thanks!
the APP source:
the example is:
var fish = formatting.fish[ template.stylerFish ];
var block = arguments[0];
var paragraph = block.defaultParagraph;
var style = block.defaultStyle;
var contextProp = arguments[1];
//Create a rule to apply to the block
//Rule is 2pt thick, solid, red and applied to all sides of the block
var rule = new fRule;
rule.sides = fRule.SIDE_BOX;
rule.thickness = "2pt";
rule.lineColor = "red";
rule.lineStyle = fRuleLine.LINE_SOLID;
//Apply the rule to the block
block.rules.addRule(rule);
//Add some padding to the block to provide some space between the rule and the content
block.paddingTop = block.paddingBottom = block.paddingLeft = block.paddingRight = "3pt";
and the "box" also can get the border:
//Apply a -2.999pt rule to the block to offset the main rule
var rule = new fRule();
with (rule) {
thickness = "-2.999pt";
lineColor = "None";
sides = "tblr";
//Apply the main rule to the block
with (rule) {
//Line thickness
thickness = "1pt";
//Line colour
lineColor = "Black";
//Sides (top, bottom, left and right)
sides = "tblr";
//Fill colour specifies background for boxing
fillColor = "#FFFFFF";
//Apply a final rule to the block to remove the offset
with (rule) {
thickness = "2pt";
lineColor = "None";
sides = "tblr";
the FOSI source:
boxing toffset=3pt boffset=3pt loffset=2pt roffset=2pt thick=1pt inclr=#FFFFFF
Can I add the lines for the end/head of pages by update the source? Or could you give me any tips please?
Your assistance will be highly appreciated in this regard.
Thanking you
TimPhelpsAnswer
Nov 19, 2014 12:13 PM UTC
This is by design.
Its purpose was to indicate that the table is continued on the next page.
A workaround is described in article 58143
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS58143
  • The method for getting a bottom rule is to create a .tmx file with the content of the following:
\TableSplitPreBrk=0
\TableSplitPostBrk=0
\TableRulePreBrk=1
\TableRulePostBrk=1
  • If you are using DITA document types, then the .tmx file must be named custom.tmx and placed in the [productpath]\inputs folder.
  • For other document types or schemas, the .tmx file may be placed in the directory with the DTD and given the same base name as the .dtd file. For example:
doctypes\mysample\mysample.dtd
doctypes\mysample\mysample.tmx
  • The .tmx file may also have the same base name as the document, if the .tmx is to apply to only that one document. In this case, the .tmx must reside in the same folder where the document exists. For example:
local\docs\sampledoc.xml
local\docs\sampledoc.tmx
TimPhelps12-AmethystAnswer
This is by design.
\TableSplitPreBrk=0
\TableRulePreBrk=1
\TableRulePostBrk=1
lxie11-VisitorAuthor
Nov 20, 2014 1:36 AM UTC
Hi Tim,
Thank you very much for your detailed answer, I will try to follow it!
