Jun 29, 2010 8:06 PM UTC
How to disable type mismatch warning in DITA reltable column
Hi, DITA and Arbortext users and gurus:
Anybody know how to disable the warning you get if you try to insert a topicref into a reltable cell and the type of the topicref does not match the type of the reltable column?
We want to put topicrefs of type "html" into the reltable, which are links to external websites (format=html, scope=external). We want to put them in the reltable column of type "topic" (actually a specialization thereof) and we get two warnings when we do. We could create a reltable column of type "html" and this works fine, but want to avoid that.
Thx
Steve Fogel, Information Architect, Oracle Corporation
    Jun 29, 2010 8:32 PM UTC
    Not sure if this will do the trick (or what side effects it may have),
    but try "set ditareltableautoinsert=off" at the command line.
    -Brandon 🙂
