Apr 5, 2020 5:12 PM UTC
How to force the adding of an undeclared attribute
With an ACL function, is it possible to force the adding an attribute (and its value) to an element although the attribute is not declared in the reference schema ?
My XML document will be not valid against the XSD Schema, but I would like to do it.
Kind regards
David
18-Opal
May 26, 2020 7:03 PM UTC
You can do this by "cheating" using the AOM and Javascript:
javascript("Application.activeDocument.insertionPoint.startContainer.setAttribute("bogus","invalid")");
In this example, it will add bogus="invalid" to the current tag (where the caret is). If you have a specific OID instead of the node where the caret is, you can use something like this:
javascript("Acl.DOMOID('" . $myoid . "').setAttribute('bogus','invalid')");
Of course, you could also do it the conventional way, by turning off context rules before adding the undeclared attribute.
18-Opal
dgopois13-AquamarineAuthor
May 27, 2020 6:09 AM UTC
Hi Clay,
Thank you again for your help.
Best regards
David
