May 5, 2017 10:22 AM UTC
how to keep the dtds locally
We would like to keep the arbor text support files locally due to network problems.
Could anyone share the location to keep the dtd and acls locally..
May 10, 2017 8:35 PM UTC
You can create a custom directory on your local drive that mirrors the folders from the custom directory in the Arbortext Program directory. Then you can point to it and other directories such as your base folder using the environmental variable APTCUSTOM.
This what we do to point to a central location. You could also store the dtds and acl in the proper custom folder inside Arbortext in your programs directory if you have access to it.
