Jul 5, 2011 2:32 PM UTC
How to manage multiple track changes in Arbortext with content management
According to PTC documentation with content management systems track changes can be only applied to single object . If the tagging for a change tracking change affects more than one object, then the system will not interpret the change tracking information correctly.
Any suggestions/workarounds?
    Jul 5, 2011 4:54 PM UTC
    Can you provide a specific example of change tracking that is not
    working for you? Also, where in the documentation is the section that
    you are referring to?
    -Brandon 🙂
    spaul1-VisitorAuthor
    Jul 5, 2011 5:22 PM UTC
    Enable change tracking on, do authoring with couple of add, modify and deletes and while checking in it gives the error (Arbortext editor 5.4 M70)
    http://www.ptc.com/cs/help/arbortext_hc/ae54m090_hc/index.jspx?id=help5078&action=show
    Jul 6, 2011 2:48 AM UTC
    Hi Sujit,
    I think you will need to workaround the out-of-the-box problems unless you
    want to explore these avenues:
    . Write your own change tracking system that respects change
    tracking across object boundaries
    . Don't use change tracking at all, but use the Arbortext Document
    Compare feature to compare different versions of a CMS object. This will
    mark all the changes for you and is more flexible because you can compare
    any version of an object to any other version and get the changes marked.
    -G
