Mar 31, 2017 7:05 AM UTC
How to open an XML file created by Arbortext Editor in FrameMake?
Is it possible to open and edit XML files created by Arbortext Editor in FrameMaker and use the same file in Arbortext Editor again?
Will there be a change in the structure? What are the requirements ?
Apr 1, 2017 11:16 PM UTC
If you're using a standard document type, such as Docbook or DITA, then it may be possible to do what you're asking. If not, then it will require someone to set things up in both FM (FM application and EDD) and Arbortext (custom doctype folder).
