Jun 30, 2015 8:40 AM UTC
how to pass through the opened xml-file as parameter in ACL?
Hi Guys,
we need to pass through the opened xml-file in Arbortext Editor with ACL to another .exe-Tool.
We know the command sh to call an external tool. But how can we pass through the opened xml file to this external tool?
Anybody an idea?
Thank you in advance for your help.
Jun 30, 2015 1:20 PM UTC
Hi Hubert,
I haven't done this myself, but I have some initial thoughts.
Will the exe be performing any changes to the XML or just referencing? If it's making changes, you may encounter errors since Arbortext locks open files from other editors.
As far as passing it to the external exe, I can think of 2 ways...
1. Pass the XML and file path as a cmd line argument to the exe.
2. Copy the content of the XML file and pass as an input stream.
Hope that helps!
-Jeff
hbestler13-AquamarineAuthor
Jun 30, 2015 1:48 PM UTC
Hi Jeff,
no, we do not need to change the xml. We only want to take informations about the opened file.
We thought about simlilar methods like suggested from you.
Our try was like this:
#mark the complete file
StartOfDocument;
EndOfDocExtend;
#selection into a variable
$sel = main::selection
#shell command
sh 'C:\testtool.exe $sel'
Unfortunately this try was without success. If we use following sh-command with a full path of a xml like:
sh 'C:\testtool.exe C:\testfile.xml' then its ok. But we need to pass through the opened xml file. Do you maybe know if there is a command or variable where the absolut path of the opened xml-file is included?
Thank you for your help.
Jun 30, 2015 2:08 PM UTC
Have you tried the function "pwd"? This will return the current working directory.
