Mar 24, 2014 2:48 PM UTC
How to rotate text in table cell
Is there a way to rotate text 90 degrees in a table row or table cell?
    Mar 25, 2014 6:59 AM UTC
    I hope it helps:
    <e-i-c gi="entry">
    <charlist charsubsetref="own-line">
    <font inherit="1">
    <hyphen inherit="1">
    </charlist>
    <att>
    <specval attname="rotate" attval="1">
    <charsubset>
    <suppress sup="1">
    <usetext source="%\ROTCCW%,#CONTENT,%\ENDROTCCW%"></usetext>
    </charsubset>
    </att>
    </e-i-c>
    Mar 24, 2014 3:47 PM UTC
    Are you using Arbortext FOSI composition, Arbortext Print Publishing composion or XSL-FO composition?
    PDF output, HTML output?
    Mar 24, 2014 3:50 PM UTC
    FOSI for PDF output.
    I hope it helps:
    <e-i-c gi="entry">
    <font inherit="1">
    </charlist>
    <att>
    <charsubset>
    <suppress sup="1">
    </charsubset>
    </att>
    </e-i-c>
    Mar 25, 2014 11:25 AM UTC
    This answer looks good.
    It matches the content described in the PTC article 38621
    https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS38621
