Oct 21, 2015 6:03 AM UTC
How to search comment tags in arbortext 5.4
Hi, I am using arbortext 5.4 and want to search tags like comment, heading, table, etc in a document.
I have used the Go to dialog box option to search the tag such as  heading, table and other all working fine. i can find the tags using the  Next and Previous button but for comment tag, this is not working well.
    18-Opal
    Oct 21, 2015 2:16 PM UTC
    Hi Satheesh--
    It works OK for me with a standard docbook sample document. The Go to -> Comment command finds the <!-- xml comments--> pretty reliably. What doctype are you using, and how are your comments marked up in the document?
    --Clay
    18-Opal
    Hi Satheesh--
    --Clay
    Nov 14, 2015 12:47 AM UTC
    Hi Satheesh,
    Were you able to resolve this, or are you possibly using a custom setup, as Clay mentioned, that may be interfering with this?
