18-Opal
July 13, 2022
How to set the default stylesheet used by Publishing engine
I have created two new stylesheets. When I use styler the default stylesheet is techinfo.style when publishing. When I rolled out the new stylesheets to the publishing engine the default is not the same. The new stylesheet seems to be the default not the techinfo.style stylesheet How do I make the techinfo.style my default.
I have tried
CS269879 How to set the default stylesheet in Arbortext Editor
and
Configuring Stylesheet Order in a List From the help
Nothing seems to change. Looking for more suggestions.
Bryon
Help topic 2112 contains all the details you need in order to understand how stylesheets are selected by Arbortext: https://support.ptc.com/help/arbortext/r8.1.2.0/en/index.html#page/admin/admin/help2112.html
Essentially you want the stylesheet name to exactly match the doctype name. You can check the doctype name in Editor by going Help -> Session -> Document tab and then check the entries there. It will even tell you what stylesheet and other paths are in effect. To debug PE, do the same steps using PE Interactive on the server.
