Nov 8, 2016 5:11 PM UTC
How to upgrade dtd from Arbortext 4.1 to Arbortext 5.4
Hi, I am trying to update my dtd file from arbortext 4.1 - to Arbortext 5.4 , here is the error I get when I try to open
the dtd file in Arbortext 5.4 '
I tried opening one of my XML documents from the network drive, with the usual DTD, but I got this message:
Invalid compiled doctype
[A15002] The compiled doctype file
C:\epicuser\ElisDTD\ElisDTD.ptd
is not compatible with this version of Arbortext Editor.
You must recompile your doctype.
When I try to compile, I get the same message again.
Interestingly, when I try to open the sample XML from the desktop, it gives me a different prompt for a stylesheet and I am able to open the doc. However, it doesn't recognize some of the tags, most notable those related to tables.
