May 22, 2014 8:47 AM UTC
How to use Proxy with GET method for Arbortext Editor 6.0
Hello all,
I have an error with Arbortext Editor as follows.
My assumption is that it could be sorted out by using Proxy server with GET method.
Is it correct?
■ Error
The public Schemas/DTDs on Web can not be loaded in the environment with Proxy server
■ Environment
Software:Arbortext Editor 6.0
Proxy Port used:15080
Others:All correspondances without used Proxy is disconnected from the Internet by FireWall
■ Details
I checked "http communication" and turned out that HEAD method to confirm the external schemas/DTDs is taken to #15080 port, though the GET method to actually obtain them is taken to #80 port.
Thank you very much.
Kind regards,
Tomomi
