Href
- 1 reply
- 1394 views
- Translate All
Conrefs and hrefs (content references and links) that worked in a previously published representation do not work in the current representation published from WIndchill, the links are right in Arbortext - this seems to have popped up since the Publishing Engine was updated to 6.1 M070 from M030. The JPG file attached shows errors in red that is appearing where hrefs were used to point users to other related content. These links appeared as expected before the Publishing Engine was updated, and afterwards these errors are the result.
Has anyone else seen this? Any ideas? I have escalated to PTC support as well, but thought I would mine the greater mind of the community as well.
