HTML Help from PE 6.0 m010
  • November 6, 2012
  • 13 replies
  • 2763 views
Just ran across a note in help indicating that I should contact services to
configure PE to publish HTML Help if I'm using a doctype other than
axdocbook. Uh, seriously? Has anyone got the info on what config changes
are required to enable a doctype to produce HTML Help?
I get a .chm however it's tiny and blank (although the title is correct).
Paul Nagai
    Just saw that one myself recently as well and was also perturbed by that
    statement.
    If you've got it running, you may find some love trying to alter
    htmlhelp.ccf in the composer directory. Beyond that, I've had trouble
    finding details on how to configure/tweak the HTML Help output so far.
    On my box, I'm not even able to select HTML Help as an option. It looks
    like one should be able to install the HTML Help Workshop and then use
    Styler or PE to generate HTML Help as output. However, the option is
    always greyed out. Using the HTML Help preview icon in Styler to try to
    fool the software, I get a message that the HTML Help Compiler is not
    installed. The full workshop, latest version including the Compiler, is
    however installed.
    Somewhere I read in the Arbortext Help Center that you have to start the
    workshop one time and close it. That didn't fix my problem.
    I'm okay with being forced to use PE to generate HTML Help if that's
    required, but it seems PE doesn't recognize that I've installed the HTML
    Help Compiler either.
    We definitely need more information on activating this feature, setting
    it up with a custom doctype, and making configuration changes.
    Cheers,
    Jason-now-adepterfied
    naglists1-VisitorAuthor
    Thanks, Jason.
    Although I had already looked inside of htmlhelp.ccf, just doing that did
    not remind me I have an htmlhelp.ccf in my 5.3 m110 custom folder that
    overrides the one in PE's /composer folder. Your e-mail triggered that
    recollection. Sadly, comparing the 6.0 m010 "standard", the 5.3 m110
    "standard, and the customized 5.3 m110 htmlhelp.ccf (which I think PTC
    provided ... I will have to do a case search on that), is not easy. They
    are all fairly different from each other and not, so far, easily understood
    at least by me.
    Waa.
    Tried running 6.0 against the 5.3 custom htmlhelp.ccf and got a dvi error.
    No output at all. Well, it was worth a try, right?
    We're running PE 6.0 m060 using the DITA application and I didn't have any problems enabling HTML Help. Just installed HTML Help Workshop 3.0 on the server (in the default directory on C:\), ran it once and restarted TomCat. From there I didn't have any troubles creating .chm file. Not sure if that helps at all, DITA might be one of the doc types that isn't affected by what the help says.
    Hello All,
    Been a while since I've been on here, and coming into this thread a little late, but...
    Seems to me the key difference in Brett's post is "restarted TomCat". That was a key thing to making a change actually take effect, even in things that might not have seemed to need it. Might have been implied in an earlier post, but since I didn't see it said...
    As Always, Just my $.02,
    Steve Thompson
    Greetings,
    Here was something I ran into when I went to Windows 7 (and beyond J ).
    For Windows 7 it is very important that this be run as an Administrator when running the HTML Help Workshop once.
    How to do this for Windows 7:
    1. Start →All Programs →HTML Help Workshop
    2. Right click on 'HTML Help Image Editor' and select "Run as Administrator".
    3. Repeat the same for 'HTML Help Workshop' as well.
    The editor process looks for certain Registry entries and it may be that these are not set unless running this program in this way.
    If this does not work, there are other specific things that the Composition Engine looks for to make that menu item be ungrayed.
    The help looks like it may need to be updated. I run HTML Help for DITA and run it both locally and on PE.
    Thanks.
    - Dave H.
    Dave Helfinstine
    Thanks Steve, David, Brett, Paul. All good info.
    Enabling HTML Help as an option on Windoze 7 is indeed facilitated by the Run as Administrator step shared by David. Tricksy.
    Also, anyone administrating PE knows it’s a good day when you’ve bounced Tomcat. Restarting Tomcat helps commit your changes and gives you a new hope. J
    Cheers,
    Jason
    Don't know if this will help since we're using axdocbook for HTML Help and not using PE. To get this running from Styler in Arbortext 6.0 M050 I found:
    For publishing in Styler, PTC Knowledgebase article: "Compose/Publish for HTML Help" Menu Option is Greyed Out in Windows 7 (TAN 151574)
    For viewing: http://www.la-solutions.co.uk/content/HTMLHelpNetworkFix.htm
    - Lou Argyres
    Thanks for the ideas, folks, but so far, none of them have helped.
    This is different from the known "can't run a .chm over the network" issue.
    The CHM does not completely build. In my 5.3 system, it is ~0.5MB. In 6.0
    it's 11k or thereabouts. It does get a proper title, so I know the XML is
    meeting my XSL ... something is falling apart at the chunking and/or
    reassembly steps.
    I will report what PTC finds/recommends
    PTC Support has replicated the issue and has R&D taking a look. I'm
    crossing my fingers they are cooking me up a customized (properly
    configured?) htmlhelp.ccf for 6.0.
