Sep 10, 2014 4:04 PM UTC
Hyphenation boondoggle.
I'm posting this because I hope it helps someone. I was having a lot of trouble with hyphenation breaking before a period
<title><xref/></title>
So it lookedlike this:
2.1 YADA/Yada-yada (YADA) Yada/Yada
. (Figure 2).
Not cool. The first period is from the xref's beforetext, the space after the first period is from the xref's aftertext and the last period is from the title's aftertext.
I played with hyphrule, keeps, wordsp, quadding, hyphenad nauseum. but this is the only thing that worked: moving the period and space to the xref's beforetext, and hitting the space bar after the period like so:
<savetext textid="beforetext" conrule="\." \,.9em&quot;=" placemnt="before"/">
This didn't work: <savetext textid="beforetext" conrule="\.\,1em" placemnt="before"/"> and putting \. \ in the aftertext didn't work, either.
    Sep 10, 2014 4:59 PM UTC
    Hi Caroline,
    A fixed space such as .9em or 6pt or 1.5pi is unbreakable, so a word space is needed to allow a line break.
    However, this does not appear to be in my book, so thanks for posting. I will add it.
    Thanks!
    Suzanne Napoleon
    www.FOSIexpert.com
    "WYSIWYG is last-century technology!"
    cleccese1-VisitorAuthor
    Sep 10, 2014 5:20 PM UTC
    Yay!
    Sep 10, 2014 5:42 PM UTC
    It appears the line would overset before the "after" word space is encountered.
    Sep 10, 2014 7:01 PM UTC
    BTW: a fixed space is useful for preventing line breaks. For example, usetext source="\Fig.\,4pt,figurect.txt" keeps "Fig." and the figure number on the same line. However, if a line break is needed but a word space is not available, the formatter will break the line at a fixed space rather than overset the line.
    Sep 10, 2014 10:29 PM UTC
    I am having that exact problem, something I did since is causing the line breaking on Figure. I can't believe I didn't try the hard space there, keeps isn't working. Thanks again, Suzanne! By posting in an attempt to help others, I actually helped myself.
    This is for a two-column layout. In some cases the title was oversetting into the next column, with some keeps, or if wordsp avoidoverfull="min".
