Sep 28, 2011 12:59 PM UTC
Import/Export Schema includes read error
Hi Everyone
I'm having a problem with import/export that i'm hoping someone else may have encountered before!
When creating a new map template, the schema (valid and working in Editor and XML Spy etc) I am loading in is coming up with an error and resluts in missing some of the element definitions. (Arbx 6.0 M010)
Error dialogue:
Schema has been loaded, however there had been some unresolved Entities, Error log file bla bla ...
Error log sample lines:
  • Group Not found :h:inline
  • Referenced Element not found :h:div
  • Referenced Element not found :h:p
It is a custom schema with a number of modules, imports, includes and dependancies. The missing parts come from references in one module pointing to elements, simple types and groups called from an 'included' xhtml-transitional.xsd (standard) module.
As everything is fine using this schema for parsing and every other XML tool i have tried, i am thinking that the DTD/Schema reader in the import/export map editor does not like either imports/includes or complex 'referenced' namespaced dependacies like this.
Has anyone else come accross any similar errors and suggest any options or work arounds?
Many thanks
Chris
PS: Support call outstanding with PTC, waiting ...
PPS: found nothing relevant in the help center
Chris Western
www.tformat.com
    18-Opal
    Sep 28, 2011 1:07 PM UTC
    Hi Chris-
    I don't have an answer for you about why it is having trouble reading
    your schema, but I just wanted to point out that loading the target
    schema is optional. If you know the structure of the output document
    pretty well, you can build the map template without loading the schema.
    Just type the element names instead of selecting things in the schema
    tree view for output steps. I frequently do this when building map
    templates, since I don't find the schema browser to be that helpful
    anyway.
    If you really want to load the schema while building the map template,
    you might be able to use a tool like Trang to make a flattened version
    of the schema that you could use with the Import map editor.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    Sep 28, 2011 3:12 PM UTC
    Hi Clay, thanks for the reply.
    I tried a few other tools to flatten it but they did not work so might have a go with Trang also, thanks for the tip.
    I'd hoped to avoid manual/non schema helper steps but looks like this might have to be the way to go.
    Best Regards
    Chris
    Chris Western
    www.tformat.com
    Dec 2, 2011 12:25 PM UTC
    At least i know i was not going mad.
    FYI; This issue was finally accepted as a high severity SPR!
