Apr 13, 2011 7:28 AM UTC
Import Object Info from a file
Would it be possible to do the following ?
When I open a iso file the object list contains the following name values for the object for example: Bn0001_prt or Bn0333_asm
1. Remove all values starting from the underscore in the name attribute ?
2. The Object list may contain 200 objects
3. Change the Object Type attribute for all objects to part and then import Object info for the objects in the list from a file
For examle:
Import data from a text file that contains the following
Name Quantity Remarks
Bn0001 2 N/A
Bn0333 1 N/A
Any help would be greatly appreciated.
