Jun 16, 2023 5:45 PM UTC
In Arbortext Editor 8.1 can you create a shortcut to styler like you could in Editor 7.x?
In Arbortext Editor 7.x you could create a shortcut to the application go to properties, then add -styler to the end of the link in the target field. It would look like below:
"C:\Program Files\PTC\Arbortext Editor\bin\x64\editor.exe" -styler
Is this not possible in 8.1?
bfriesen
bfriesenAnswer
18-Opal
Jun 19, 2023 12:32 PM UTC
Should be the same. My path (below) is the same as above for editor 8.1.1.0. Just make sure that when editor 8.1 was installed that styler was also checked to be installed. if not you should be able to go add programs and modify it to include styler.
Bryon
bfriesen
bfriesen18-OpalAnswer
18-Opal
Bryon
