Indexing and the Army
Anyone have experience with creating indexes with the Army/LOGSA stylesheets?
I've inserted a number of index refs that the DTD allows, but those are not the index tags Arbortext looks for...and I'm looking for a pointer on where to go from here.
I'm assuming I'll have to write a parser and run it on a flattened book then add the PDF'd index pages later...but I'd sure prefer not to.
Thanks in advance for pointing me to the starting line...
    Johh,
    Which version of the Army DTD and which style sheets are you talking about?
    Lynn
    Army-supplied LOGSA production.dtd plus stylesheets v1.5 in this instance, although I have 1.2-1.5 installed.
    Arbortext version 5.4
    Product is to be XML TM with PDF print format.
    I've handled half a dozen bugs/conflicts between v1.5 and 5.4 to get it mostly working so far. Now I'm being asked about the indexing functions. The -23 manual will have 3000 work packages - what a mess to do by hand. The word this morning from LOGSA is that they still code indexes by hand.
    John T. Jarrett CDT
    Tech Writer II, Tech Pubs, ILS,Land & Armaments/Global Tactical Systems
    T832.673.2147 ext 1147 | M 512.736.7031 | -
    BAE Systems, 5000 I-10 West, Sealy, Texas USA 77474
    www.baesystems.com
    Arbortext can build custom indexes using tags for index entries and/or that
    are just part of the content. But maybe there's something more mysterious /
    restrictive going on in the standard dtd/stylesheets you're talking about.
    Are you allowed to modify the stylesheet? Is it FOSI? Look for e-i-c's for
    beginning <ix... often=" (sometimes?)=" grouped=" near=" the=" end=" of=" the=" e-i-c's<br="/>rather than in alphabetical order.
    On Mon, Jan 11, 2010 at 10:10 AM, Jarrett, John T. (US SSA) <
    > Thanks,
    > John T. Jarrett CDT
    > Tech Writer II, Tech Pubs, ILS, Land & Armaments/Global Tactical Systems
    > T 832.673.2147 ext 1147 | M 512.736.7031 | -
    > www.baesystems.com
    I'll do my best to answer your questions 😉
    The final output is to go through the XSL-FO stylesheets, not the FOSI.
    The Mil-Spec the DTD is based on uses (of course) totally different tags for its indexing, but they are close enough theoretically I could edit the DTD (with the Arbortext tags) and the stylesheet (hmmm, don't see a stylesheet for an index...may have to write one) to convert back to LOGSA tags...but I don't see how I can tell Arbortext to use a custom Index stylesheet.
    XML tag in a document:
    id ID #IMPLIED
    indxref IDREF #IMPLIED
    ref1 CDATA #IMPLIED
    ref2 CDATA #IMPLIED
    ref3 CDATA #IMPLIED
    ref4 CDATA #IMPLIED >
    Here's a sample tag in the document:
    <indxref ref1="Safety" ref2="First" aid&quot;=" ref3="Cuts" and=" scratches&quot;=">
    The ref# is hierarchical just like Arbortext's appear to be (i.e., this would be listed under S - Safety, subhead First Aid, then Cuts and Scratches with a page number).
    Here's an oversimplified output example ("wp" refers to work package - an individual chapter or set of instructions in these types of manuals):
    <aindx>
    <title>ALPHABETIC INDEX</title>
    <col.title>Subject</col.title>
    <col.title>WP Sequence #<col.title>
    <alphaindx>A</alphaindx>
    <indexentry>
    <title>Accessory Section</title>
    <wpno wpref="access_sect"/">
    <pageno>15</pageno>
    </indexentry>
    <alphaindx>B</alphaindx>
    <indexentry>
    <title>Back Cover</title>
    <wpno wpref="backcover"/">
    <pageno>285</pageno>
    </indexentry>
    </aindx>
    John T. Jarrett CDT
    T 832.673.2147 ext 1147 | M 512.736.7031 | -<">mailto:->
    www.baesystems.com
    I can almost guarantee you if you are using the LOGSA provided FO it WILL NOT do an index.
    Personally I've been trying to get the index requirement removed from 40051 as it is a nightmare to deal with in markup, in the Army's paperless delivery, it is superfluous (you have full text search available in the PDF).
    Lynn
    > > id ID #IMPLIED
    > ref1 CDATA #IMPLIED
    > ref2 CDATA #IMPLIED
    > ref3 CDATA #IMPLIED
    > <aindx>
    > <indexentry>
    > <pageno>15</pageno>
    > </indexentry>
    > <indexentry>
    > </indexentry>
    > </aindx>
    > John T. Jarrett CDT
    > www.baesystems.com
    18-Opal
    January 11, 2010
