Aug 1, 2016 3:09 PM UTC
Insert Graphics
Dear Users,
I am trying to insert graphics (customised image located in C:/XYZ/ABC.jpg) from the "Insert Graphics" in Styler -> Generated Content menu.
But it throws a error "A61191" and does not show my customised image from custom directory. But works well for Arbortext OOTB graphic folder.
Pls advice how to overcome this.
-Best Regards,
Sriram Rammohan
    TimPhelpsAnswer
    Aug 7, 2016 7:53 PM UTC
    Have you tried adding C:\XYZ to your graphics path variable?
    You can use the environment variable APTGRPATH or the Arbortext Variable grapihcspath.
    graphicspath can be added to via Tools > Preferences > Category and select Graphics Path.
    Add the path there, or you may add the value using the Arbortext Command Language (ACL).
    See Arbortext Editor's Help Center for further details (Help > Help Center).
    Aug 2, 2016 9:50 AM UTC
    Create a folder, save the stylesheet, map, images in the same folder.
    TimPhelps12-AmethystAnswer
    Aug 8, 2016 4:28 AM UTC
    Tnks a lot Tim.
