Inserting A Comment Before The Root Element
Inserting a comment node before the root node is not as simple
as I thought it should be.
I devised a way and share it accordingly:
test document:
<mydoc>
<mytitle>Sample MyDoc</mytitle>
<mybody>
First
para
</mybody>
</mydoc>
test JavaScript:
// source D:/work/acl/cloning/commentTrial1.js
var globalObject = this;
(function(){
// create a testing namespace
globalObject["commentTrial1"] = {};
// use "cls" for convenience
cls = globalObject["commentTrial1"];
cls.identify = function(){
print("you have called commentTrial1.identify()");
cls.insertCommentBeforeRoot = function(text) {
var doc = Application.activeDocument;
// scrub to avoid interpolation of quotes
var scrubText = text.replace(/\"/,"\\\" );
var commentNode = doc.createComment(text);
// from
file:///C:/Program%20Files/Arbortext/Editor/docs/javadoc/aom/index.html
// getDocumentElement()
// This is a convenience attribute that allows direct access
// to the child node that is the root element of the document.
// For HTML documents, this is the element with the tagName
"HTML".
//var root = doc.getDocumentElement();
//root.insertBefore(commentNode);
var nl = doc.getChildNodes();
var root;
for (var i=0; i<nl.getlength(); i++)=" {<br="/> print(nl.item(i).getNodeType() + " " +
nl.item(i).getNodeValue());
// 1 = Element
// 8 = Comment
if (nl.item(i).getNodeType() == "1") {
root = nl.item(i);
print("found root element");
break;
var parentRoot = root.getParentNode();
//parentRoot.appendChild(commentNode); // places after
closing tag
parentRoot.insertBefore(commentNode, root);
commentTrial1.insertCommentBeforeRoot("This comment should be
before the root tag;"
+ " created by commentTrial1.insertCommentBeforeRoot()");
Oracle Email Signature Logo
John Laurence Poole | Principal Software Engineer | 650.607.0853
Oracle User Assistance Engineering
M/S 2op1070
500 Oracle Parkway
Redwood Shores CA 94065-1677
Oracle Instant Chat: john.poole
The statements and opinions expressed here are my own and do
not necessarily represent those of Oracle Corporation.
    delete:
    add at the end a 2nd test:
    commentTrial1.insertCommentBeforeRoot("Here's a test of quotes: He
    said,\"Hello World.\");
