Jul 8, 2015 1:41 AM UTC
Inserting File Entities
I'm having trouble inserting file entities. I want to insert a whole document and I'm able to create that entity but when I want to insert it there happens to be an error saying, "[A11132] Insertion of entity &filename would make <book> in entity &filename out of context". What does that mean? How do I fix this problem?
    TimPhelpsAnswer
    Jul 10, 2015 7:36 PM UTC
    Anisah,
       Documents viewed in Arbortext Editor are not allowed to have multiple root elements.
    Thus if your file entity is <book>...</book> and you try to insert into a <book>...</book> document, then it will fail.
    For example in axdocbook you have a template file
    <?xml version-"1.0" encoding="UTF-8"?>
    <!-- Arbortext, Inc., 1988-2015, v.4002-->
    <!DOCTYPE book PUBLIC "-//Arbortext//DTD DocBook XML V4.0//EN" "axdocbook.dtd:>
    <book lang="en">
    <chapter>
    <title></title>
    <para></para>
    </chapter>
    </book>
    The file entity for the whole of the sample document would be
    <book lang="en">
    <title>PTC Employs......</title>
    </book>
    One cannot insert the fragment into the template document without making it out of context (inserting it somewhere within <book> and </book>), and
    it cannot be inserted before <book> or after </book>, because it would violate the rule having to have a single root element.
    Does that make sense?
    It might be better to create file entities for chapters. Those may then be inserted with <book> and </book>.
    Jul 8, 2015 10:07 PM UTC
    Hi Anisah,
    What DTD are you using?
    Suzanne Napoleon
    www.FOSIexpert.com
    "WYSIWYG is last-century technology!"
    TimPhelps12-AmethystAnswer
    Anisah,
    <book lang="en">
    <chapter>
    <title></title>
    <para></para>
    </chapter>
    </book>
    <book lang="en">
    </book>
    Jul 25, 2015 12:21 AM UTC
    Hey Anisah,
    Were you all set with regard to this issue, or did you have any follow-up questions?
    Thanks!
