Invalid Schema/DTD File
- 2 replies
- 3020 views
- Translate All
Hello Everyone, I work in IT support and a user came to me with an arbortext issue for me to troubleshoot. Im new to this job and extremely new to arbortext. He needs to open an XML file and a DTD file together. when opening either of the files no matter the order, Arbortext gives an error that it cannot parse the DTD/XML File. The DTD file specifically produces the error "Invalid Schema/DTD File". The error is related to XML compliance and i have no idea how to fix it.
ive searched around quite a bit and found this possible solution -
"Click on Cancel and choose Tools > Compile Document Type to compile your document type and use your existing document type with the parsing rules used in previous versions of ArbortextEditor"
We are using Servgistics arbortext, im not sure if thats something different then that article was referencing but there is no "Compile Document Type" under tools on the top bar.
Sorry if I worded this poorly I would really appreciate it if anyone could point me in the right direction, thank you
