Sep 23, 2015 12:31 PM UTC
Is it possible to encrypt the ACL code?
Is it possible to encrypt the ACL code or is there a solution to prevent users to read or modify the ACL code ?
David
    18-Opal
    Sep 23, 2015 1:50 PM UTC
    Hi David--
    I don't know of a way to do this. You might be better off taking an AOM/Java approach, maybe using an obfuscation tool to make your Java classes harder to reverse engineer.
    --Clay
    18-Opal
    Hi David--
    --Clay
    dgopois13-AquamarineAuthor
    Oct 1, 2015 6:56 AM UTC
    Hi Clay,
    Thank you for your help.
    David
