Is there a shortcut for "Find Next Change" in Arbortext?
I apologize for arbortext newbie question, but I don't see a quick option for going through changes in a document. I do not see a toolbar shortcut, key stroke shortcut, or recording a macro option available.
Is file menu "Tools-->Change Tracking-->Find Next Change" only option?
Thanks in advance for help.
    JayRAnswer
    Found it. Find-->Go To, select Changes
    JayR1-VisitorAuthorAnswer
    If you search the Editor install tree recursively using a text editor or find tool looking in .acl files for the word "change", you can locate the following alias:
    NextTrackedChange
    Which resolves to:
    change_tracking_find(oid_caret(), oid_caret_pos());
    Either of those could be mapped to a keyboard shortcut you are willing to "steal" from its normal function OR placed more prominently on the Find menu. Search for the "map" command for the first idea and "menu_add" for the second.
