Dec 7, 2016 8:27 AM UTC
Is there a way to add exception rules for hyphenation for the APP engine?
Hi all,
I am current published German documents using APP. I have a problem with hyphenate for "klicken" word. It is hyphenated as "klik-ken", which is not correct. I'm not sure if there are any other wrong cases. So I would like to make an exception for it. However, using .exc file doesn't work for APP. Does anyone know how to add Hyphenate exception rule for APP engine?
Die for any clue!
Thao
Dec 7, 2016 6:25 PM UTC
Are you using the bulit-in German/German_long/German_reformed or the add-on Dieckmann hyphenator? For typesetting of German language, most publishers seem to prefer the Dieckmann hyphenator. If you are using the add-on Dieckmann hyphenator, I'm not sure if it uses the same exception dictionary method, but the standard way is to load an exception dictionary into an APP .ex stream, then activate the exception dictionary using <?thye>.
Dec 19, 2016 8:18 AM UTC
Thanks Gareth!
It turned out that the type of German language is the problem, changed it to de-1996 solved the issue. You are right there!
I'm very new to Arbortext as well as APP. So I don't know what is Dieckmann hyphenator is, but it's very useful for the future.
