ISO-Animation export to CGM
i'm using Arbortext IsoDraw 7.3 to create animated graphics.
To Start the animation i create Hotspots.
When i export the iso-file to CGM with Profile WebCGM 2.0 the animation doesnt exist anymore.
The Hotspots points onto the group which is animated, but the animation doesnt start.
Does anybody know which properties do i have to enabled/disabled to get animated graphics in CGM?
From my understanding the animation functionality only works through the IsoView tool and plays the actual IsoDraw file. No way to export to CGM.
You may want to look into Creo Illustrate. This allows you to export the animation to various formats (unfortunately I do not believe CGM) based on the codecs you have loaded on your machine.
Hi Trevor,
thanks for your answer.
I have a CGM-file which has animations. This animations are played in IsoView well.
Unfortunately i cant rebuild this file. If i edit the associated iso-file and export this to cgm the animation doesnt work anymore. It seems that isoview doesnt detect the animation.
Are there any properties i can edit in IsoView?
