Dec 14, 2011 11:21 PM UTC
ISO Draw 7.1 license issue
We have one copy of IsoDraw 7.1 and FlexLM installed on a server providing a floating license. The one IsoDraw user recently got a new computer. Now when we point the "PTC_D_LICENSE_FILE" variable to the server, we get the message "License Request Failed for Feature ISODRAW". I checked communications between the server and the PC and found no issues. I was able to use a diagnostic program to successfully talk on port 7788 between the client and the server. All firewalls and antivirus were opened up. The FlexLM log files show that 1 license is available, but don't log any attempts to connect or use the license. Any suggestions?
Only one thing I can think of. On the user's previous system, he might have had IsoDraw 7.0. Would a license that supports 7 also support 7.1?
    Dec 15, 2011 7:20 AM UTC
    Christian,
    I suggest to check your license file. It has to contain the following line:
    INCREMENT ISODRAW ptc_d 7.1 .......
    Martin Hanak
    Dec 16, 2011 10:52 AM UTC
    Christian Brown wrote:
    ...Only one thing I can think of. On the user's previous system, he might have had IsoDraw 7.0. Would a license that supports 7 also support 7.1?
    Why you haven't installed in the beginning version 7.0 and haven't tested it on the new computer?
    Dec 16, 2011 7:05 PM UTC
    Problem solved. The user was using IsoDraw 7.1 and the license was for 7.0. We incremented the license and it works now. Thanks for the replies.
    Sep 27, 2019 9:51 AM UTC
    Hey,
    how you incremented the License?
    Greetings Timos
    Sep 27, 2019 2:44 PM UTC
    You can purchase a license: https://www.ptc.com/en/partners/find-your-partner
