18-Opal
May 9, 2012
Isodraw 7.2 M20 Issues with models rotating / moving from 2D to 3D
- 0 replies
- 1289 views
- Translate All
We have an issue with Isodraw not sure where the problem is.
We have a jt file that is exported from SE ST3. We open our pre sized template and place the image on the standard layer in isodraw. We then rotate it to the view that is required, convert to 2D, scale and move it to fit on our template. Convert back to 3D. The model will rotate again with out any user input. If the user places a second assembly on the standard layer, when he goes to 2D, then back to 3D the second model will move and rotate itself also. We have also had this happen just opening an iso file, using the cut command then, rotating, then 3D to 2D and back causes it to rotate all crazy again.
Any suggenstions would be great.
Bryon
