IsoDraw 7.3 does not show colors when importing CGM
My illustration looks great in IsoDraw, so I export it to WebCGM 2.1 for downstream processes.  It looks great in the downstream process, but if I import the .cgm file back to IsoDraw it is missing line colors, line weights, leader-line halos, and area colors to name a few.
18-Opal
April 14, 2021
If you used contour shading to add colour you will need to select create contour fills on the camera button (2D button)
Bryon
Apparently I just needed to hit ctrl+k.  What does ctrl+k do?
18-Opal
April 14, 2021
It shows a preview. I have attached a shortcut list. Hope it helps.
Bryon
